Blazer Trouble
Old Oct 6, 2008 | 11:41 AM
AnCuth123's Avatar
AnCuth123 is an unknown quantity at this point
Default Blazer Trouble
I am having a little issue with how my Blazer is driving. I have been wondering about an issue i have with accelerating.
-For one my vehicle revs at 400-600rpm idle
-when i start it up it wont go right away; moves sluggish
-When i hit the gas pedal, it really has to slow down and shift or something before it gets faster
My friend and think i may need a new distributor, does that sound about right or...?
I also have the gas gauge issue and had to replace the alternator a couple months ago
Any advice?
Old Oct 6, 2008 | 11:47 AM
2002XTREME's Avatar
2002XTREME is an unknown quantity at this point
Default RE: Blazer Trouble
could you post up what year veh you have and any imp other info you can post about it..the more info there is its easier to help with the problem..
Old Oct 6, 2008 | 12:03 PM
AnCuth123's Avatar
well its a 2000 LT, and it is pretty much stock
Old Oct 6, 2008 | 12:22 PM
WolfPack's Avatar
I'd say no to the new distributor idea. You may need a new dist. cap and rotor though. But I'm kinda thinking transmission.
When you say it has to slow down...do you mean it stumbles on itself, or does it feel like the transmission is freewheeling and downshifting? What do your RPMs do when it slows up?
If it's the downshift youre feeling, I'd say check the transmission fluid level first..but we need some more info
Old Oct 6, 2008 | 12:38 PM
AnCuth123's Avatar
Well when i say it slows down, it will stumble and the tach wont move(this is from a stop), other times the tach will fly right up with not much acceleration ( this is when i am driving)
Old Oct 6, 2008 | 01:13 PM
blzR's Avatar
blzR is an unknown quantity at this point
I had similar issues & it turned out to be the main computer
was fried,checkout in yourprocess of eliminations.
Old Oct 6, 2008 | 03:07 PM
AnCuth123's Avatar
How would i check/fix that?
Old Oct 6, 2008 | 04:48 PM
WolfPack's Avatar
There is alot to check through before going to a fried computer..
Old Oct 6, 2008 | 09:31 PM
blzR's Avatar
I really should NOT of said:
"fried"
asthe main computerfunctioned almost perfectly minus the sudden accelerating,asthough i was showing off like a clown looking for a stunting ticket from the cops.It would also jump and lope when warm up in the morning like a ghost was hitting the gas pedal every 10-40seconds.But it would run perfect UNTIL it started to get warm..then it was hell all dam day!
Here's a tip for you:
Go look under your Blazer and look for the possibility that some meathead welded either your muffler or cat converter.I found welds on mine and i strongly bet that is what goofed up my computer,by not unhooking the battery!
(just a 1% possibility for you)
fivemillerz
Jul 17, 2006 08:26 PM
dcjones
Jan 19, 2006 10:54 PM
danimalvt
Engine & Internal
Dec 20, 2005 08:32 PM
luvfroses
Jul 7, 2005 11:44 PM
sully
Jun 8, 2005 08:06 AM
