Starting trouble with 90 Blazer
Old Dec 19, 2005 | 08:14 PM
danimalvt's Avatar
danimalvt is an unknown quantity at this point
Default Starting trouble with 90 Blazer
Hello everyone!
This is my first post on this forum.
Unfortunately I am not starting trouble with the Blazer but having trouble starting.
I recently purchased a 1990 Blazer 4.3 4WD standard with a plow for my driveway.
The starter went and after removing the passenger side header I was able to change it.
Now the new starter makes a loud clunk noise when I try to start the truck. The battery is new and the starter is receiving 12 volts.
I moved the truck which was a task with the plow down to try another spot on the gear.
The starter came with shims but the flyer said it was only required for Escalades and other late model vehicles.
I am hoping that the engine is not seized.
Any help/tips is greatly appreciated.
Thanks,
Dan
Old Dec 19, 2005 | 08:43 PM
Default RE: Starting trouble with 90 Blazer
Every starter that I have put in came with a shim pack and a check block/rod. The check block or rod should fit between the starter shaft and the gear. If it doesn't, you need to add shims until it does. Some starters come with a block that is wider than it is tall. It serves as a go/nogo check. The narrow side should fit, and the thick side should not. Most starters aren't that precise of a fit so they just send a short rod that needs to fit.
I would add some shims and see how it goes. It can be a major pain in the butt. I know!!!
Good Luck
Old Dec 20, 2005 | 08:17 PM
danimalvt's Avatar
Thanks for responding swartlkk. I purchased the starter at Advance Autoparts and it is a Paladium. It came with a shim pack but no check block or rod. Any suggestions on how else I could check if the starter is aligned properly? Is it ok to shim it at an angle or should it only be straight? Thanks.
Old Dec 20, 2005 | 08:31 PM
I would just start with shims so the starter stays straight. If you find that you can't get it aligned properly with the shims in straight, you may have to shim it with a half shim only on one side. I wouldn't advise this though. It *shouldn't* be necessary.
Old Dec 20, 2005 | 08:32 PM
If you can't get it to work with one shim pack, take the starter back and have them replace it, plus give you an extra shim pack.
ynoth
Jan 8, 2010 01:28 AM
kingoffrost
Oct 2, 2008 07:28 PM
jaredwaugh
Nov 8, 2007 03:49 PM
fivemillerz
Jul 17, 2006 08:26 PM
dcjones
Jan 19, 2006 10:54 PM
