Blend Door Actuator on 96 blazer
Old Nov 4, 2019 | 06:11 PM
Czechman90's Avatar
Czechman90 is on a distinguished road
Default Blend Door Actuator on 96 blazer
I have the part to replace it, i just cant seem to find the area where it goes. If someone could shed some light on this area that would be great. I know its going out because when i use the heat nothing happens but when its on vent i can feel it.
Old Nov 6, 2019 | 11:37 AM
Czechman90's Avatar
Originally Posted by Czechman90
I have the part to replace it, I just can't seem to find the area where it goes. If someone could shed some light on this area that would be great. I know it is going out because when I use the heat nothing happens but when it is on vent I can feel it.
Update, I found where the air door actuator is located. well, it seems like it is in a very tight spot. is there another way to put that new part in without taking that whole dash apart.
Old Nov 6, 2019 | 08:50 PM
On the later models we go through the glove box but I think on 96s it might be much harder.
Old Nov 7, 2019 | 06:20 AM
Czechman90's Avatar
I have to go threw the glove box and i notice its harder to fix it that way. An i am not taking the dash apart for that. I guess i will have to deal with it the way it is.
Old Nov 7, 2019 | 11:11 AM
On my 99 I found I could remove a small panel on the engine compartment side of the heater/blower box and see the blend door. If you can do this too, perhaps as a temporary solution you can manually move the door for full-heat during the winter?
I'm attaching my pictures below.
The view is looking towards the firewall. The opening for the panel I removed is circled in red.
The blend door is indicated by the red arrow. The axis on which it rotates is highlighted in yellow.
Old Nov 7, 2019 | 02:28 PM
Czechman90's Avatar
Thanks, for the photos. I will have to manually do it that way. I don't know why gm had to make part locations such a pain in the butt to get too.
Old Nov 7, 2019 | 03:53 PM
... I don't know why gm had to make part locations such a pain in the butt to get too.
That's how you know it is A Quality GM Product! LOL
jojocarreno
Jun 4, 2020 05:04 PM
Silvermount
Nov 18, 2018 10:04 PM
mattjphoto
Dec 26, 2014 08:51 AM
ravenhurst
Feb 16, 2010 05:53 PM
markrd
May 8, 2009 01:39 PM
