blinker
Old 04-25-2010, 05:45 PM
Djmanic669's Avatar
Djmanic669 is on a distinguished road
Angry blinker
Hey there, so I have a 97 s10 blazer with the 4.3 vortex in it its the four door model with a center floor automatic shifter transmission a month or so ago I had a pro set up my trailer light after mine were cut well it blow the flasher unit and I replaced it and had my mechanic look at it and he fixed the wiring well a couple weeks ago I hauled a trailer and when I got home (after the lights worked fine). The lights weren't work so I went and got a new flasher unit and that didn't help I checked my fuses all were fine my bulbs are good what could have happen????
Old 04-25-2010, 05:47 PM
Do your 4-ways work? How about your lower brake lights?
Old 04-25-2010, 05:52 PM
Djmanic669's Avatar
What is the four way and all my lights work encluding my hazzards
Old 04-25-2010, 05:54 PM
4-ways = hazards.
What lights are not working specifically? Only the trailer lights? Or the turn signals on both the trailer and truck? Or something different?
Old 04-25-2010, 06:03 PM
Djmanic669's Avatar
I have no blinker on the trailer or the truck but I do have hazzards so I no the bulbs are good and I know there must be a connection
Old 04-25-2010, 06:07 PM
Ok. So using your terms, blinker == turn signals.
The turn signal flasher module is separate from the hazard flasher module, however they are located side by side and are identical. Which one did you replace?
If your back up lights work, then the 'TURN B/U' fuse is still intact.
Old 04-25-2010, 06:36 PM
Djmanic669's Avatar
Back up lights work and I changed out the flasher fuse for the blinkers it was clearly marked on it and the hazzard fuse is fine
Old 04-25-2010, 06:44 PM
Swap the hazard flasher module and the turn signal flasher module.
All signs point to a faulty turn signal flasher module.
Do the turn signals work properly with the trailer unhooked?
Old 04-25-2010, 06:47 PM
Djmanic669's Avatar
Did that and bought a new one no difference
Old 04-25-2010, 06:49 PM
I'll ask again because it seems you missed it:
If the signals work properly, then your flasher is not made for the additional load that trailer lights put on it and you need a HD flasher.
If they do not work properly, then you have to dig into the wiring because everything else is working properly.
Quick Reply: blinker
