blinker blinking
Old Apr 9, 2010 | 04:43 PM
terryrae's Avatar
terryrae is on a distinguished road
Default blinker blinking
Hi with the signal leaver in the neutral the left front signal flashes real fast and the back is not lit at all when I push the leave down for the left side everything works fine But when I move the leaver up for the right side its like putting the four ways on.
Old Apr 9, 2010 | 05:18 PM
mykeboy01's Avatar
mykeboy01 is on a distinguished road
...start surfing junkyards for a new blinker stalk. New ones run $200+. But before you go and spend any money, check ALL of the fuses, and associated wireing, to make sure nothing is crossing. The fast blinking to the left side suggests a short in the system. Usually, when a bulb is out, the bulbs will blink fast. But since it is happening in the neutral position. What year? Does it do this when the cruise control is switched off?
Old Apr 10, 2010 | 01:14 AM
terryrae's Avatar
its a 2000 it does in the driveway to I check it tomorrow what you think and the trailer wiring to tks
Old Apr 10, 2010 | 04:01 PM
mykeboy01's Avatar
Is that a stock hitch setup? Or, did you wire it yourself?
Old Apr 10, 2010 | 04:39 PM
terryrae's Avatar
I cut the hitch wires off and caped them checked bulbs and fuses couldn't find anything so i took the maltifuction switch out it was a worn and the 4 way was glued together not from me I'll get one on monday the wiring plug for it goes into a block on the colom does it just pull out is there tabs or is there screws i didn't want to brake it so i left it till i see the one from the weckers. thanks
blazintexas
May 1, 2012 06:01 AM
doodlebug_04538
Apr 15, 2007 11:58 AM
allforenot
Feb 22, 2007 12:04 AM
wick001
Dec 2, 2006 10:05 PM
tambo
Mar 4, 2005 05:44 PM
