Blinker Issue. Help!
Old 02-17-2008, 10:09 PM
o0ian0o is an unknown quantity at this point
Default RE: Blinker Issue. Help!
check out this recall, it's for a pretty similar issue, could apply to some of you guys...
http://www.autorecalls.org/2000/14915.shtml
Old 02-17-2008, 10:41 PM
fla_blazer4x4's Avatar
fla_blazer4x4 is an unknown quantity at this point
had the same thing kinda with my 05 driveing on the high way everytime i went to use my blinkers the light wouldint come on on the dash or the light outside so i messed with the fuses no good, then messed with the hazards and they worked brand new.
Old 03-09-2008, 04:58 PM
mexisexisuperman's Avatar
mexisexisuperman is an unknown quantity at this point
ok i got the mulifunction switch replaced and i still have the same issue. What else could it be? Help!
Old 03-09-2008, 07:22 PM
Pull apart the tail lights and look for corrosion in the bulb sockets.
Old 03-09-2008, 08:43 PM
cccfabioccc's Avatar
cccfabioccc is an unknown quantity at this point
i dont know what your exact problem is but couldnt it be your hazard module as well?
Old 03-11-2008, 08:13 PM
ok. just got done looking at the bulbs for corrosion and nothing. what else?
Old 03-11-2008, 08:42 PM
Do you have a trailer plug? Even if you do not, check up on the rear frame rail for a bundle of wires tucked up either on top of the frame or in the frame. I am not sure if the trailer harness was standard on a '95, but it is possible that, if so equiped, the harness has shorted out due to corrosion.
Old 03-13-2008, 12:45 PM
JBLAZE is an unknown quantity at this point
MY 98 BLAZER'SLEFT TRUN SIGNAL IS DOING THE SAME THING, BLINKS THREE TIMES FASTER THAN THE RIGHT SIDE ?? HAD THE CLICKING NOISE UNDER THE DASH FOR A SHORT WHILE THAT WENT AWAY BUT THE RUNAWAY LEFT TURN SIGNAL IS STILL HAY WIRE , WHATS THE FIX ??CHANGED BULB AND FLASHER, NO HELP
Old 03-26-2008, 05:28 PM
Ya you are right. the harness had corrosion all over. So far so good for a whole day. they are operating welleven when i press the brake pedal. thanx. i'll let you know if they stop working again.
Old 03-26-2008, 10:15 PM
Yooper's Avatar
Yooper is an unknown quantity at this point
Did you check your Blinker fluid level????
blazintexas
05-01-2012 06:01 AM
jdpilot
03-23-2010 06:31 PM
eightyninegt
01-30-2010 02:25 PM
enigmattic
01-02-2009 09:06 AM
kngflp
11-12-2006 03:45 PM
Quick Reply: Blinker Issue. Help!
