blinking battery dash light
Old Jul 16, 2010 | 05:39 PM
rughstr's Avatar
rughstr is on a distinguished road
Default blinking battery dash light
i have a 2002 ls s10 blazer; had some work done and another alternator put in; the voltage meter registers that it is charging, but the battery light intermittently blinks on; any one have ideas as to the cause; thanks
Old Apr 13, 2011 | 09:49 PM
halfton24's Avatar
halfton24 is on a distinguished road
i am having the same problem with my 96
Old Sep 14, 2012 | 11:50 AM
Tiffany Holland's Avatar
Tiffany Holland is on a distinguished road
I have a 2001 and I am having the same issue
Old Sep 14, 2012 | 07:52 PM
LannyL81's Avatar
Suggest checking the red wire connection on the rear of the alternator. It could just be loose or if the person that installed the alternator put too much torque on the nut which may have messed-up the insulator causing an intermittent short.
Other thoughts are a loose battery cable(s) or corroided ends.
Old Sep 15, 2012 | 10:58 AM
burned's Avatar
burned is on a distinguished road
Its the voltage regulator inside the alternator. Get another alternator, or get that one field tested.
I suggest going with an AD244 model from the full size vehicles. They bolt right in and only require a 1" longer belt to work.
I upgraded to the AD244 and never been happier. Way more amp output.
damageinc98
Jul 12, 2010 10:47 PM
myinkfreak
Oct 18, 2009 07:41 AM
Ridinblazer
Feb 8, 2008 08:24 PM
tolleyc
Jul 29, 2007 05:57 PM
allforenot
Feb 22, 2007 12:04 AM
