blower Filter??
Old Mar 9, 2008 | 05:45 PM
Aquahallic's Avatar
Aquahallic is an unknown quantity at this point
Default blower Filter??
Folks,
It seems my blower on my heat and A/C is not so strong when I don't have it on MAX A/C (recirculate) as soon as it is pulling air from outside there's not very much air blowing.... Is there somekind of filter for the outside air?? It's a 95 Blazer 4.3 L. 4WD
Thanx,
Aqua
Old Mar 9, 2008 | 05:49 PM
rriddle3's Avatar
Default RE: blower Filter??
No, there isn't, but check the cowl inlets under your wiper arms and see if there is debris in there that might be blocking the air intake.
Old Mar 9, 2008 | 07:09 PM
^^Yup^^ No filter option available for the S-series. You should definitely pull up the plastic cowl area and check for leaves, pine needles, or any other debris down near the inlet of the fan.
Old Mar 9, 2008 | 07:29 PM
Aquahallic's Avatar
Those are clear... 'least looking at the plastic grills.. I'm guessing debri sometimes goes through those and gets in there and gets clogged... could it be smaller debris getting plugged in the fins of the A/C core or heater core?
*Combining consecutive posts. Please use the edit function if no one has replied since your last post, thanks. TBB
Is there some sort of grill/grid or is it just an open duct into the fan where smaller debris would go past and possibly plug the fins on the heater core?
Aqua
_____________________________
Aqua
95 Blazer LT 4WD
Old Mar 9, 2008 | 07:34 PM
Aquahallic's Avatar
Aqua
maxvamp
Oct 31, 2020 08:19 AM
SWATPARAMEDIC
Jan 1, 2010 03:12 PM
highlife756
Nov 16, 2009 03:57 PM
dashyman
Nov 28, 2005 01:49 PM
aspenpup
Jul 3, 2005 06:56 AM
