Blower motor does not work
Old Jan 11, 2010 | 07:05 PM
tmzg29's Avatar
tmzg29 is on a distinguished road
I have a 1999 Blazer and the blower does not come on. I can select any speed and the motor does not push any heat. Not sure if it is the motor or the resister. Any easy ways to check before I go cutting the blower motor cover off. And did I say it is cold up here.
Thanks,
Every once in a blue moon it will come on. It has not worked for a couple weeks and I started it this morning and it worked. I came out of work and started it and it did not come on at all. Could it be bad brushes on the blower motor.
Old Jan 12, 2010 | 04:49 PM
terry s's Avatar
terry s is on a distinguished road
Thanks,
It sounds like a bad switch, bad connection somewhere or the motor is going bad. I suggest you check for voltage at the motor with a test light or volt meter. Try the switch in all positions. Also try wiggling the wire and connectors if you get no voltage. If you get voltage in all positions the motor is probably bad. You could then hot wire the motor and see if it works.
If the resistor is bad the motor should run on high speed only.
maxvamp
Oct 31, 2020 08:19 AM
TrainChaser22
Dec 4, 2019 12:27 PM
Amelia23
Sep 29, 2012 05:31 PM
leebell
Apr 23, 2011 02:42 PM
dec1000
Dec 1, 2008 06:13 AM
