Blower motor resistor, or relay?
Old Jun 26, 2012 | 11:44 AM
ojibwe_guy's Avatar
ojibwe_guy is on a distinguished road
Default Blower motor resistor, or relay?
I have a 97 Blazer LS 4x4 4 door. I replaced the broken blower fan switch, but found the plastic around the switch mounting area to be melted. This caused the switch to stick, so I Dremel'd off the melted stuff and the switch moves freely.
However, the blower still only works on the top two settings - let's say Hi and Medium-Hi. The lower two positions don't turn the fan on at all. I searched and found some info that points to the either the resistor or the relay. How can I test them to see which one is bad? Both are about the same price, but I'd rather not replace something that isn't bad. Thanks!
Old Jun 26, 2012 | 01:12 PM
50lb_cat's Avatar
When the fan only works on the highest setting its the resistor that is bad.
Old Jun 26, 2012 | 01:31 PM
ojibwe_guy's Avatar
Gonna try and replace that.
Thanks Large_Cat
Old Jun 26, 2012 | 01:49 PM
50lb_cat's Avatar
No problem! There is a good article in the DIY section if you need a how to.
Logan
17
Mar 29, 2012 10:59 PM
shellos8
Oct 20, 2010 09:10 AM
EnyChevyUK
Aug 25, 2009 07:24 PM
shadetreeranger
TrailBlazer GMT360/GMT370 (2002-2009) Tech
Apr 15, 2008 10:00 PM
blazer_girl
Jul 21, 2007 07:08 PM
