Daytime Running Lights
Old Feb 7, 2010 | 06:43 PM
515Blazer's Avatar
515Blazer is on a distinguished road
Default Daytime Running Lights
Not sure if this is the correct area but i want to completely disable my daytime running lights and my automatic headlights, can somebody help me out
Old Feb 7, 2010 | 06:46 PM
Spectreblazer's Avatar
Banned
Spectreblazer is on a distinguished road
resistor or push your dome overide 4x
https://blazerforum.com/forum/showth...ht=auto+lights
Old Feb 7, 2010 | 06:58 PM
515Blazer's Avatar
the dome override doesnt work on a 98 (should have said it a 98 4dr LS) and the resistor will still leave me with the daytime running lights right?
Old Feb 7, 2010 | 07:06 PM
Banned
i believe there is a fuse you can pull for the drl. or if they are on a separate bulb, just remove the bulbs
Old Feb 7, 2010 | 07:19 PM
515Blazer's Avatar
the system turns the highbeams on durning the day at half voltage so there dim, and when it gets dark the head lights on and i cant turn them off and i dont want to do the ebrake trick
the closest thing i could find to a fuse is a diode in the fuse panel, not sure if i wana remove that just yet
Old Feb 7, 2010 | 07:23 PM
Banned
if you look at that last page of the link i got above. some guy asked the same question and they explained it.
Old Feb 7, 2010 | 07:29 PM
515Blazer's Avatar
thanks for the link, ill look for relay tomarrow
Old Feb 7, 2010 | 07:31 PM
Banned
yup no problem
Old Feb 7, 2010 | 08:44 PM
NVANZEE's Avatar
pulling the relay out will get rid of the DRLs but you will only have the passenger side high beam. The drivers side wont work. Do a search and you will see what pin needs to be bent over on the relay. I think its 86 but im not sure.
Old Feb 8, 2010 | 06:20 AM
515Blazer's Avatar
if all else fails i could just wire the left high beam bulb to the right with a relay cause im also gona wire it so my lows come on with my highs for better visability with the highs on
antman94
Mar 7, 2011 08:12 PM
Benedict1337
Dec 10, 2010 08:30 AM
drefda
Oct 5, 2006 01:32 PM
greengoose89
Jun 2, 2006 03:09 PM
RedBlaze
Sep 14, 2005 01:28 PM
