Boggs and dies under heavy throttle
Old Sep 22, 2011 | 09:35 PM
levi1a's Avatar
levi1a is on a distinguished road
Default Boggs and dies under heavy throttle
I have a 99 blazer with a 4.3. I am trying to diagnose a bog under heavy throttle. If you slowly crack the throttle it will rev fine, but it you gun it it will fall flat on its face. The only code I have is a p0102 low output Maf. I cleaned the sensor and the code hasnt came back. I verified fuel pressure 49-55 lbs and engine vacuum is around 19-20 hgs with a steady needle. I pulled and cleaned the egr valve also. Another thing is the idle is erratic at times fine at others. I found that air temp sensor was unplugged and when I plugged it back in the engine died. It will not run with the air temp sensor plugged in. Any help you can give is greatly appreciated this thing is driving me crazy.
Old Sep 24, 2011 | 08:27 AM
dougn85's Avatar
dougn85 is on a distinguished road
Have you checked the TPS Throttle Positioning Sensor?
Old Sep 24, 2011 | 10:24 AM
bromanjr's Avatar
bromanjr is on a distinguished road
If you plug in the temp sensor when it is not running, will it start?
If not the sensor or wiring is probably bad.
When I had a bad fuel pump (cheap non-Delco brand), my pressure at idle was fine, but when I revved the engine in gear and the brakes on, the pressure would dip and the engine would falter. New Delco pump fixed it.
Old Sep 24, 2011 | 07:27 PM
....I verified fuel pressure 49-55 lbs ....
There's your problem. Key on, engine off, fuel pump running: Pressure must be 60psi to 66psi and must remain above 55psi for 3 to 5 minutes after the pump shuts off. Here are the details on how to test the fuel delivery system: https://blazerforum.com/forum/tech-a...agnosis-23038/
SnowBlaZeR2
Jun 26, 2012 11:54 AM
vortec bowtie
16
Jun 1, 2012 10:12 PM
2000jimmbo4x4
Sep 14, 2010 08:51 PM
Kendo
Sep 22, 2009 11:12 AM
Poligono
Nov 3, 2008 06:01 PM
