Brake pedal adjustment
Old Sep 21, 2016 | 11:09 PM
johnnylovsey's Avatar
johnnylovsey is on a distinguished road
Default Brake pedal adjustment
I have a 2003 Blazer 4x4 L/S the brakes are not leaking the pads are not very old both front and back. My question is would there be an adjustment to the brake pedal to bring it up a little higher.Since with no leaks of any kind and 4 wheel disc that has a low pedal but hard. Know pulling or any failure other then low pedal. Is there a way to bring the pedal up a bit higher.
Old Sep 23, 2016 | 10:07 AM
Raybz's Avatar
Raybz is on a distinguished road
Check for bulging rubber hoses at each wheel.
Flush the fluid ( DO NOT let the res run dry, if it does you going to have to bleed the ABS unit, NOT EASY!)
Brake fluid attracts water, water is more easily compressed than brake fluid
kg82082
Oct 11, 2015 06:50 AM
zach bjorge
Mar 17, 2011 06:49 PM
god_zilla00000
Nov 8, 2009 09:17 AM
93Blazer4X4
Aug 18, 2008 01:57 PM
ChrisAttebery
Jul 3, 2007 12:31 PM
