Brake sensor?
Old Mar 13, 2008 | 07:25 PM
kharndt's Avatar
kharndt is an unknown quantity at this point
Default Brake sensor?
'97 Blazer. I'm noticing a squeal from the front end. I can only hear it at very slow speed when the window is down. WhenI depress the brake (but, I'm still moving) the squeal stops. As soon as I release the brake I hear it again. I'm told it's a brake sensor telling me it's time for brake service. Is that true? If so, it doesn't make sense that the sensor "deactivates" (and the squeal stops) when I depress the brake.
Thanks for any insight!
Karen
Old Mar 13, 2008 | 08:30 PM
Default RE: Brake sensor?
Not a sensor per say, but the scrapper on the pad. It is a wear indicator that will make noise before the pad material is all the way gone, theoretically warning you before you damage the rotor.
Old Mar 13, 2008 | 08:57 PM
kharndt's Avatar
So, to clarify, this scrapper or wear indicatoris "engaged" (makes the squealing noise) when the car is in motion and is"disengaged" (stops making noise) when the brakeis applied?
Thanks!
Old Mar 14, 2008 | 09:03 AM
Due to pad flex, yes, this can happen as you describe it. The longer you drive it, the more constant the noise will become.
joey
Aug 27, 2012 06:33 PM
GM hater
Jan 9, 2010 02:32 PM
theeviltwinn
Oct 23, 2009 06:37 AM
daniel010
Feb 2, 2009 06:50 AM
Spartan66
Jul 11, 2008 02:34 PM
