Brake vibration in pedal
Old Jun 9, 2017 | 09:19 AM
Dustin Grant's Avatar
Dustin Grant is on a distinguished road
Default Brake vibration in pedal
I had my front brakes replaced just the brakes were changed the rotors I told where fine. Couple months later when slowing down under 10 mph or slower I get a vibration in the brake pedal and a moaning sound. Happens intermittently. Sounds like its the front left where the moaning is coming from. After my research on the forum and on the net. I believe it may be the rotor. Or could it be the ABS? Your thoughts are welcome. Thanks
Old Jun 9, 2017 | 11:08 AM
Brian Hinzpeter's Avatar
Brian Hinzpeter is on a distinguished road
Is there a vibration when braking at highway speeds? 70-80 mph?
Old Jun 9, 2017 | 02:56 PM
No Brian pedal only vibrates when I am stopping and the truck is under 10mph. Only happens intermittently. No highway speed vibrations at all
Old Jun 9, 2017 | 05:22 PM
Sure sounds like intermittent ABS activation likely due to a dirty or faulty wheel speed sensor. There is a tech article on what to check to determine the cause.
Old Jun 10, 2017 | 08:37 AM
Thanks for your input swartlkk. Is that tech article about ABS on this website?
Old Jun 11, 2017 | 06:07 PM
Responding from my phone or I would include a link to the article. You can have a look at my signature below for a link to the tech article index post. It should be one of the first few in that post.
Old Jun 12, 2017 | 10:22 AM
Thank you I found the Tech article
kg82082
Oct 11, 2015 06:50 AM
justinjumpstart
May 12, 2014 08:04 AM
NinosBlazer
Sep 20, 2012 08:31 PM
zach bjorge
Mar 17, 2011 06:49 PM
lowe42
Dec 23, 2008 12:34 PM
