brakes
brakes
brake pad hard as a rock .replaced power booster 2years ago.is it thesame thing maybe .have bleed brakes and abs both
RE: brakes
Its quite possible the booster is at fault again. If you remove the check valve from the front of the booster, you should hear a rush of air. If it does not do this, then the booster bladder is most likely shot.
poertsch
04-23-2016 01:05 PM
goslats
15
07-31-2015 09:19 AM
218persuader
08-20-2010 06:11 PM
