brakes
Old Aug 1, 2010 | 01:48 AM
m3ch's Avatar
m3ch is on a distinguished road
Default brakes
so my brake light is on, constantly, my brakes arnt working like they useta
what could it be??? air in the line? i noticed i was a little low on fluid topped it off and still didnt work real good, i can stop but not like before...
Old Aug 1, 2010 | 02:25 AM
4x4blazerguy's Avatar
The reason for the light is the proportioning valve has shut of either front or rear brakes. Check for blown wheel cylinders or a blown caliper. You should see brake fluid leaking. Or you have lost a shoe or a pad. My guess is a blown wheel cylinder though. After you fix it you will have to center the proportioning valve.
Old Aug 1, 2010 | 10:36 AM
m3ch's Avatar
ok i might have lost a pad because my brakes were bad, but i didnt no they were that bad
my rear brakes btw =)
Old Aug 2, 2010 | 11:01 AM
m3ch's Avatar
okay so i replaced the brakes, and i lost some fluid, but no leaks and the brakes still are not working right, im going to check the fluid,pump the brakes, etc see if i could get it working
Old Aug 2, 2010 | 06:10 PM
GunsOfNavarone's Avatar
GunsOfNavarone is on a distinguished road
Check for a fluid leak, especially on the ground where the fuel tank is. A high fail area for the brake line for Blazers in Northern states.
Old Aug 2, 2010 | 06:23 PM
m3ch's Avatar
Okay it's a blown wheel cylinder it's leaking from behind the wheel can Someone explain his to change them please??
Old Aug 2, 2010 | 07:06 PM
m3ch's Avatar
Well upon closer examintation it looks like it's comming from the line could it still be the wheel cylinder?? I don't have tools atm so I can't change the cylinder yet
poertsch
Apr 23, 2016 01:05 PM
goslats
15
Jul 31, 2015 09:19 AM
mowermechanic
Jan 31, 2012 09:01 AM
218persuader
Aug 20, 2010 06:11 PM
rnjohnson
Nov 16, 2009 08:39 AM
