brakes and dying
Old Oct 1, 2009 | 11:14 AM
falcone86's Avatar
falcone86 is on a distinguished road
Default brakes and dying
ive recently started having this problem where i go to push on my brake and its really stiff. and when i do apply my brakes at a light the car stutters and occasionaly dies. any solutions would be greatly appreciated.
Old Oct 1, 2009 | 03:34 PM
terry s's Avatar
terry s is on a distinguished road
It sounds like you have a vacuum leak in the power booster. The power brakes derive the power assist from engine vacuum. A vacuum leak will cause the engine to run rough or die.
Old Oct 2, 2009 | 08:08 AM
falcone86's Avatar
could that also be the reason the brakes are really stiff, if so can i get it repaired or does it need to be replaced
Old Oct 2, 2009 | 12:22 PM
Gibbles's Avatar
Gibbles is on a distinguished road
check the rubber hoses, make sure they are in good condition and not cracked/falling apart.
If worst case you may need to replace it, I have another hard drive for my laptop with my GM manual loaded, I can look it up if needed (does not run well on vista )
Old Oct 2, 2009 | 12:34 PM
terry s's Avatar
Yes, if it leaks vacuum you will not get the assist that gives you power brakes. Check the big hose going to the booster and the check valve at the booster but if the engine only runs rough or dies when you step on the brake the leak is inside the boster. If so you need to replace it as repairing it is not a simple task.
Old Oct 2, 2009 | 12:39 PM
strange's Avatar
strange is on a distinguished road
My sons 95 Blazer had that same problem, replaced the brake power booster and problem went away!
Old Oct 2, 2009 | 06:56 PM
falcone86's Avatar
thanks for all your help terry, strange, and gibbles. a huge load of my mind
Old Oct 3, 2009 | 03:04 PM
falcone86's Avatar
sorry one more quick question. everytime i see parts they come with or without the master cylinder. do i need a new master cylinder?
Old Oct 3, 2009 | 03:51 PM
bandidolenny's Avatar
I would just change out the booster... you can always do the master cylinder later if it acts up.
Dyspayre
Sep 6, 2012 03:01 PM
wallacereid
13
May 8, 2012 12:30 PM
pfunknasty
Apr 23, 2012 10:36 AM
kgkern01
Apr 19, 2011 12:22 PM
Big L
Mar 14, 2008 12:25 PM
