Brakes failed on highway
#41
Ant time a 2nd Generation Blazer/ Jimmy/ Bravada has rear pads replaced with the original calipers, the calipers should be rebuilt or replaced. It was disappointing that whoever did the rear pads in 2009 did not replace the calipers- might of saved you a lot of hassle. The rear calipers are well known for seizing after pads/ rotors are replaced. Budget calipers as part of any rear brake pad replacement. One can buy "stacked" calipers from RockAuto, where the calipers are shipped with new pads already installed, simply take off old caliper and replace with new caliper. ALl you have to do is bleed the lines.
#42
#43
I don't know if this is related to the brake problems I have had, but is it normal to hear a soft "hiss" sound when I apply the brakes? I don't know if it could be a vacuum problem because the A/C seems to work fine and the 4WD locks in okay (I can jack up the front left wheel and turn it like 2-4 inches and then the front driveshaft and the CV shaft on the opposite side will try to rotate and then lock since the truck is in park). The actuator under the battery seems to lock the front axle properly (I can look when I pull the headlight off).
#44
I had a grand prix that did the same thing .within a weeks time the brakes failed twice .
1st time Tow to garage could find nothing wrong
2nd time pull over called for a ride while i was waiting brakes returned to normal function ???
When i say fail i mean all the way to the floor and not even the slightest drag
owned the car for 3 more years never did it again
I never replaced anything but pads but it sure did play havoc on my nerves when driving
no one could explain to me what happened
Spartan66
07-03-2008 12:11 PM
