Brakes and serpentine belt!
RE: Brakes and serpentine belt!
Hey if6was9,
No worries - I tested the brakes out last night properly, foot to the floor felt the ABS kick in.. they are working but still quite easy to put the foot down. So you say only 2 inches movement, but guessing after those 2 inches it should be more firm and then the ABS kicks in when braking hard? Pretty sure somewhere in between the first 2 inches of movement the brakes kick in and slow the beast really well.
As for fully bleeding the system, we did that but don't think we did it properly! Do you happen to know what the difference between DOT 3 and DOT 4 brake fluid is?
Cheers
Nate
Cheers
Nate
DOT 3 is the older fulid spec and is required in these trucks. DOT 4 is a newer spec, some DOT 4 fluids are compatible with DOT 3 systems. It is a partly or fully synthetic fluid that will not compress correctly in a DOT 3 system unless it specifies DOT 4/3
ORIGINAL: natenorrish
Hey if6was9,
Cheers
Nate
Hey if6was9,
Cheers
Nate
luvmychevy
06-08-2011 11:46 AM
luigi408
02-03-2010 03:07 AM
abig84
12-31-2009 05:40 PM
ooohtodd
04-03-2007 09:27 PM
