Broken Brake Lines!!!
Old Oct 31, 2007 | 11:29 PM
Bigblock396's Avatar
Bigblock396 is an unknown quantity at this point
Default Broken Brake Lines!!!
So I was going home one particular evening when a deer jumped out and I slammed on my brakes. In doing so, my brake light came on and my pedal went to the floor. after i stopped ( I have little brakes) I find a puddle under the drivers side door. The rubber line is blown open. Is there any easy fix??? what should I do? My front brakes still work fine, just spongy pedal.
Old Nov 1, 2007 | 07:01 AM
Default RE: Broken Brake Lines!!!
Replace the affected component(s). Simple as that. Once you have the repair completed, bleed the brakes.
I definitely would not recommend driving your truck with a failed or failing brake hydraulic system.
Old Nov 1, 2007 | 08:46 AM
ok, after further inspection, the steel brake line rusted out on the drivers side in between the driver and passenger door. I have to replace the whole length of the line right? Any and all advice is greatly appreciated!
Old Nov 1, 2007 | 11:49 AM
Burlisonm's Avatar
Burlisonm is an unknown quantity at this point
As far as I know you do have to replace the whole line, you can get with a parts store and they should be able to get you one that is already made for the year of your truck.......I'm pretty sure
Old Nov 1, 2007 | 11:50 AM
Burlisonm's Avatar
What year is it? Is it steel from one end to another? If so I had to replace a line on my old blazer (93) andit was late so be bought a steel line and bent it to match and it worked and did not leak for 4 years until I go rid of it.
Old Nov 1, 2007 | 11:51 AM
If you can find good line before and after the bad section, then you can cut and flare the original line, splicing in a replacement piece to cut down on the cost. But flaring old brake lines can be problematic...
And you could just replace the whole line, bending up a straight replacement line (or lines) to get the job done.
Old Nov 1, 2007 | 02:48 PM
Ok, thank you so much for all your input!
Tortex53
Jan 9, 2011 08:50 AM
flipzat
Nov 29, 2009 05:41 PM
bang4dabuck
Feb 28, 2009 04:13 PM
primo
Jul 19, 2007 06:50 PM
