Broken Hazard switch
Old Jul 29, 2013 | 05:54 PM
ExpressEN1's Avatar
ExpressEN1 is on a distinguished road
Default Broken Hazard switch
I searched and found a decent write up on changing out the heater core on my 99 Blazer. I seen the warning about the hazard switch on top of the steering column and still managed to break the switch. I found a write up to replace the switch. I went to the Chevy dealer to get a new switch and the guy tells me it is part of the turn signal switch and that $15.00 part will instead cost me $234.00. Did I miss something? I see the switch on e-bay and in the parts stores. Is the hazard switch not replaceable by itself?
Old Jul 29, 2013 | 07:14 PM
JavierEscalonJr's Avatar
JavierEscalonJr is on a distinguished road
Only 234? they tried to sell me a whole steering column, just order the part number for the switch at least that's how it was for my 96. Good Luck
Old Jul 29, 2013 | 07:47 PM
ExpressEN1's Avatar
Thanks, if I can ever gey the dang steering column cover off i'll do that. I found 2 screws on the bottom (below hazard switch), took them out and the cover would not come apart. I will look at it some more tomorrow after work.
Old Jul 29, 2013 | 09:11 PM
WitchingHour's Avatar
WitchingHour is an unknown quantity at this point
Spend the $20, $25, or so, and get a Haynes or Chilton manual. It'll save you a lot of headache as opposed to trying to figure it out on your own.
Old Jul 30, 2013 | 07:10 AM
blazer down under's Avatar
blazer down under is on a distinguished road
guess that's one difference between the s10 and the t10 my hazard switch is in the dash near 4x4 switches?? R.H.D
Old Jul 30, 2013 | 09:03 AM
Twip's Avatar
you can buy the hazard switch from rock auto. its not the best quality but it will work. i bought 2 seeing as i have 2 blazers. i fixed the broken one and had a spare. then i realized that the one that i "fixed" didnt really fix anything. so i had to yank it back out, which broke it, but i didnt care because i had a second one. the second one i basically took apart before i installed it and stretched all the springs behind the contacts. that is why the first one didnt work for me. it wasnt making good contact on the inside and i only had blinkers and a 3rd brake light. no lower brake lights. if that makes sense. just get the one from rock auto, take the contacts off, stretch the springs and you will be good to go.
Taymacjack
16
Feb 21, 2020 08:42 AM
blazin97
Oct 27, 2009 09:04 AM
joe
Jul 7, 2008 02:31 PM
TonyOneX
Apr 14, 2007 12:34 AM
