Broken TB cable connector help
Hey guys
So I was working on my 1997 Blazer to replace the Spider injectors, and in the process of re-assembly, I broke a plastic connector that connects one of two braided wire cables to the Throttle Body.
Photos:
Now from what I've been looking into, this appears to be the Cruise control cable and NOT the Accelerator cable. Problem is, I can't find a replacement for this connector. Everything I find is for the 2000+ style, pictured here:
My question(s) are as follows:
1: Does anyone have a source/link to a version of the connector that will fit mine? From what I've seen the 2000's version does not fit the earlier models due to a different sized hole.
2: Is this cable in fact JUST the cruise control connector cable?
And going off of 2,
3: Is it perfectly fine and safe to drive the vehicle with this cable disconnected for the time being, in case this is a Junkyard only part?
Thanks in advance,
Border
Photos:
And going off of 2,
Thanks in advance,
Border
that is the Accelerator cable, NOPE: Cruise control cable, Is probably a junkyard only part but in theory you could use a 2000s connector im just not sure how they are connected to the cable.
My thought was just grabbing a TB and cable from a later year in a junkyard, as they're more prevailiant. Thing is, I'm not sure if the other end of the cable is the same hookup as mine. If it's not, puts a damper there.
I read Here in the last post the guy stating that the newer style doesn't fit quite right as the hole it goes into is too small?
