burning smell and smoke from the vents
Old Oct 18, 2020 | 10:47 PM
GeorgeLG's Avatar
Sounds like its not a leaking heater core. My guess is two separate problems. A blower motor that is failing and an external coolant leak. Water leaks can really travel so I would just start running my fingers around every hose, fitting and hosing looking for some green/red. If that doesn't do it you can pressurize the system at rest and listen or add some UV dye.
George
Old Oct 18, 2020 | 10:57 PM
Noah Langer's Avatar
Noah Langer is on a distinguished road
Thanks a lot for your help George. I'll let you know when I sort it all out.
Old Oct 18, 2020 | 11:28 PM
GeorgeLG's Avatar
Two more thoughts on your coolant leaks. A spray bottle of soapy water when the system is at pressure is a good diagnostic tool and don't forget to check your freeze plugs.
George
Old Oct 19, 2020 | 03:44 PM
5 more cents worth of a thought.
When the heater-core has been changed many people omit the foam/rubber gasket around the tubing passing the firewall. If the leak is in the engine bay onto the exhaust it may pull these fog/fumes in through there.
Old Oct 19, 2020 | 06:21 PM
GeorgeLG's Avatar
+1
George
cbenslay
TrailBlazer GMT360/GMT370 (2002-2009) Tech
Dec 29, 2010 06:45 AM
DennyBlazer
Dec 2, 2010 06:35 AM
daniel010
Jan 24, 2009 01:36 AM
Edwards00
Jan 14, 2009 08:59 PM
killerelfboy
Jan 11, 2008 12:44 PM
