Buzzing nois somwhere near rear wheels.
Old Mar 11, 2009 | 05:50 AM
marparts's Avatar
marparts is an unknown quantity at this point
Question Buzzing nois somwhere near rear wheels.
Hi,
I have a 96 4,3 4door 4x4 blazer.
Today i heard a buzzing noise near rear wheels.
I think it is the fuel pump. But why it is running when ignition is off.
Old Mar 11, 2009 | 07:09 AM
How long did you hear it run for? Have you confirmed that it is the fuel pump? If you remove the fuel pump relay does the noise stop?
Old Mar 11, 2009 | 10:50 AM
marparts's Avatar
It was only a gess that is if fuel pump. buzzng was coming from rght side of a car. and i was unable to locate fuel pump relay :S. I found relay box from a clove box but removing thed did'nt stop the buzzing.
Old Mar 11, 2009 | 11:16 AM
95blazerlt's Avatar
95blazerlt is on a distinguished road
fuel pump relay i beleive is under the hood. not 100percent sure .. does the sound go away when you stop or does it make the noise when your moving...?
Old Mar 11, 2009 | 11:25 AM
marparts's Avatar
I dont know about moving but whan i stop the engine and take off the key it keeps buzzing.
Yesturday morning i had to take the bus to work because my battary was dead:S
I looked under the hood but i didn't see any box that looked like fuse box.
Old Mar 12, 2009 | 01:22 AM
marparts's Avatar
Yesturday eavning I unpluged the battary because it was still buzzing.
Today I put battary back on and everything was quiet. I drove to work, turned off the engine and buzzing was gone. I hope it will not come back.
Old Mar 12, 2009 | 08:51 AM
Weird. Maybe a relay stuck closed and the battery disconnect allowed it to open...
Old Mar 13, 2009 | 04:44 AM
marparts's Avatar
yep. I thin it is the relay. Sometimes when i stop the engine it will keep buzzing and sometimes not. When it is buzzing and i unplug the pattary for a few seconds and plug it back it will keep buzzing. Probably it is just worn out.
waterbill
Jan 10, 2011 05:29 PM
DSMayo
Mar 15, 2010 07:21 AM
jcookmp
Nov 6, 2009 03:46 PM
sktdarkstar8
Aug 28, 2006 02:37 PM
sergiovv
Nov 2, 2005 10:54 AM
