'02 Blazer LS 2WD 4.3 Noise near rear of engine
Old Jan 6, 2011 | 12:36 PM
waterbill's Avatar
waterbill is on a distinguished road
Default '02 Blazer LS 2WD 4.3 Noise near rear of engine
First, I'm happy to have found this forum for Blazer owners. While far from being a master mechanic, I hope to contribute something to someone, someday!
When the engine's cold and just started up, there is an er-er-er-er-er noise which almost sounds like it's coming from the radio. It speeds up with increased engine rpm, to a point, then stops. Back at idle speed, it returns. When the engine warms up, it disappears. The radio is off. The A/C is off. I recently replaced a tensioner pulley and eliminated another noise. Checked all other accessories on belt drive. Could this be a distributor noise?
Old Jan 6, 2011 | 04:51 PM
step66's Avatar
HMMM! I 've never heard a dist loud enough in the unit when running,and I have had plenty go south in 36 years of owning GM trucks! Maybe pull it and spin it by hand-if any resistance is felt:replace it! Good Luck! step66
Old Jan 10, 2011 | 05:04 PM
waterbill's Avatar
I checked again, and it's not the distributor. The serp belt was removed and pulleys all seem ok(replaced Tens. pulley). Noise is in the front, actually. Belt is like new. Spraying water on belt quiets noise. I wonder if buying another $30 belt is the right move. Old belt has about 20Kmi on it.
Old Jan 10, 2011 | 05:29 PM
step66's Avatar
-Check the tensioner,any abnormal movement?-Could be the water pump as well-getting ready to go-all easy fixes!
Make sure all accesories(PS,AC,ALT) spin well!
Best to you!
Blue thunder 2000
Aug 20, 2012 10:45 PM
ryanleh
Sep 3, 2011 08:46 AM
Chrismacster
Apr 2, 2009 06:57 PM
marparts
Mar 13, 2009 04:44 AM
sharpy
Jul 11, 2006 01:04 AM
