A/C blinking
Old 12-26-2010, 10:09 AM
Squirrel75's Avatar
Squirrel75 is on a distinguished road
Originally Posted by swartlkk
I do not have a picture. When I cleaned the drain on my old '00 Bravada, I already had the inner wheel well out on the passenger side. That was a lot of work, but made getting at things easier. You can't really see the drain hole from under the truck looking up at the frame rail, but a small mechanics mirror will help bring it into view. It will be on the lowest point of the HVAC housing at the firewall. It is easiest to clean using compressed air.
Thanks, I will wait to be back in my garage to have a look and try to access the drain! Humidity is reducing with the weather but still is in. I'll try and keep you posted if I find something related to the drain.
Thanks again.
Old 02-02-2011, 10:50 AM
Squirrel75's Avatar
Hello,
After doing some research I found that my heater core was leaking enough to creat fog in the cabine but not enough to leak in the foot well.
So I ordered a heater core on rockauto.com with a fuel filtre and studied the diy's on this forum. With a friand of mine it took us 5h to change the heater core and flush the entier colling system to start with som brand new dexcool.
While we were there me changed the engin oil and filter, greased the front end and swaped the tires.
The leak on the heater core was very small. A tiny crack near a solder that would leak only if very hot.
Every thing works fine after the swap.
I wanted to thank you all for the precious information regarding the heater core change.
By the way my blazer is a 2002 4 door LT 4x4 with 123000km.
tolleyc
07-29-2007 05:57 PM
doodlebug_04538
04-15-2007 11:58 AM
allforenot
02-22-2007 12:04 AM
wick001
12-02-2006 10:05 PM
tambo
03-04-2005 05:44 PM
Quick Reply: A/C blinking
