a/c blower
Old Jun 23, 2008 | 04:02 PM
Izzy207's Avatar
Izzy207 is an unknown quantity at this point
Default a/c blower
I was wondering if anyone has encountered a problem with the ac blowing just on the front window. For some reason it stopped blowing through the front vents completely. I would like to try and fix this if it is at all possible.
Thanks guys...
Old Jun 23, 2008 | 04:07 PM
Default RE: a/c blower
Somehow you have lost vacuum to the HVAC controls. This vacuum is supplied through the vacuum switch on the transfer case if you have 4wd. Run a search cause I know I have posted the vacuum routing and diagnostics before.
Old Jun 24, 2008 | 10:34 AM
KA3AX's Avatar
KA3AX is an unknown quantity at this point
I had a very similar problem if not the same. I ended up changing a vacuum "pump" or whatever it's called that controls the airflow. My blazer had three of them and one was acting funny so I changed it with one from a junk yard and it started working fine. But to do that you have to take off the whole dashboard and that is not too difficult but will take 2-5 hours.
Hope this helps,
keep us posted on the process
maxvamp
Oct 31, 2020 08:19 AM
SWATPARAMEDIC
Jan 1, 2010 03:12 PM
highlife756
Nov 16, 2009 03:57 PM
dashyman
Nov 28, 2005 01:49 PM
aspenpup
Jul 3, 2005 06:56 AM
