A/C Clutch doesnt turn on
Old Apr 25, 2008 | 09:08 AM
ride_da_lightnin's Avatar
ride_da_lightnin is an unknown quantity at this point
Default A/C Clutch doesnt turn on
So I went to check my AC and I noticed my clutch is not turning on, I checked the recharge nozzle and very little air came out...My question is, Does there need to be freon in there to turn on the ac clutch or should that run regaurdless?(obviously when the switched is turned to a/c) thanks
Old Apr 25, 2008 | 11:02 AM
garry2000blazer's Avatar
garry2000blazer is an unknown quantity at this point
Default RE: A/C Clutch doesnt turn on
There is a low pressure cutoff switch on the accumulator to keep the compressor from burning itself up when there is insufficient freon in the system. You can remove the connector to the cutoff switch and short the two terminals with a paper clip to see if that is the problem. The clutch should engage when you short across the terminals, just don't let it run very long like this...this is only a diagnostic check.
If the clutch doesn't engage, you may have a bad compressor or clutch.
Now that I think about it, if you have a voltmeter you should check for 12 volts at the connector at the clutch before you try shorting the cutoff switch connector. If you have 12 volts at the clutch, the cutoff switch isn't the problem and you probably have a bad clutch.
spider21
Nov 30, 2011 09:51 PM
MintyMadness
Jul 13, 2011 12:37 AM
J_man01
Sep 5, 2009 05:40 PM
Red03
Sep 25, 2008 08:37 PM
shaka1111
Feb 13, 2006 02:23 PM
