A/C Clutch Replacement Question
Old Nov 7, 2010 | 12:23 AM
speterson1011's Avatar
speterson1011 is an unknown quantity at this point
Default A/C Clutch Replacement Question
A bearing in my a/c clutch has gone bad. Its a deafening noise. I have been driving my other vehicle because I'm afraid the clutch will lock up and burn the belt up. Does anyone have any experience with this? I've heard you need a special tool to do it. Any help would be great. Thanks
Old Nov 7, 2010 | 10:39 AM
blazinloud's Avatar
you can unplug the harness on top then the clutch wont engage at all and fix it later. i just did it.
Old Nov 7, 2010 | 01:48 PM
If the bearing that the pulley rides on is going bad, unplugging the clutch won't relieve the issue. If its the bearings in the compressor, then yes.
As far as removing the clutch/pulley goes, both the HT6 & V7 compressors that my references mention require a few different special tools to get down to the pulley bearing.
Old Nov 11, 2010 | 05:28 PM
Thanks for the help and info. I ended up getting a new compressor from NAPA and put it in and recharged my system. New vacuum lines too. Big difference
austrochevy
Aug 8, 2013 09:04 AM
ashelton96
Jun 13, 2012 10:27 PM
masterchf117
Jul 17, 2011 09:32 AM
MintyMadness
Jul 13, 2011 12:37 AM
Red03
Sep 25, 2008 08:37 PM
