A/C Compressor with Defrost....
Old Aug 29, 2012 | 06:00 AM
kendog's Avatar
kendog is on a distinguished road
Default A/C Compressor with Defrost....
Having a slight issue with my climate control and hoping this is the place to post this. I've discovered in my '04 4x4 that when I turn my selector switch to the defrost position my A/C compressor kicks on. It blows out to the windshield, sure enough, but my spider sense is telling me the A/C should only come on when I select it. Also, and maybe related, my vent door comes open above 2000 rpm and will let fresh air in, no matter what my selector is set to. I've been hunting for a vacuum leak but to no avail. Any ideas?
Old Aug 29, 2012 | 06:30 AM
Blue00Blaze's Avatar
Blue00Blaze is on a distinguished road
Your A/C compressor should come on when you select defrost because it helps with defogging your windshield faster.
Old Aug 29, 2012 | 06:31 AM
rriddle3's Avatar
The compressor running on the defrost setting is normal, it removes the excess moisture from the air. Don't have any idea why the vent door is acting that way, though.
Old Aug 31, 2012 | 04:33 AM
kendog's Avatar
never had a vehicle do that with the defrost. nice to know that's normal. thanks.
Old Aug 31, 2012 | 10:14 AM
mrspeedy69's Avatar
mrspeedy69 is an unknown quantity at this point
Every vehicle I've owned does this.
Old Oct 29, 2012 | 01:40 PM
kendog's Avatar
actually gonna remove the fuse for the compressor when it gets cold enough to need it regularly. don't need the extra wear on my compressor or motor. still hunting for a damn reason the vent door comes open on its own.
Old Oct 30, 2012 | 12:04 PM
neo71665's Avatar
It does it on my 78 nova and 69 gmc. Its not something new. Like said it removes the moisture from the air to help defrost and defog the windows faster. Frankly running the compressor helps keep it in shape vs letting it sit for a few months with all the oil draining to the lowest point in the system.
Old Oct 30, 2012 | 08:06 PM
What exactly do you mean, "vent door"? If you're referring to the recirculation door, (next to passenger side kick panel) it should only be closed when you select MAX AC. It has one orange vacuum line attached to the actuator.
Old Nov 1, 2012 | 04:45 AM
kendog's Avatar
guess I'm thinking about this wrong, but I was under the impression that if the climate control was turned off, there should be no air blowing through the vents. never had another vehicle that did. HOWEVER, as my rpm's increase, so does the amount of air coming through the vents. all of em. no blower, just what can be forced in depending on how fast I'm travelling. so if I go 50mph at 1700rpm, nothing from the vents. drop down into 3rd, and I get air from the vents. on max a/c, where the recirculation door is supposed to be open and fresh air closed, if my rpm's go above 2000 I notice it starts blowing much warmer. which is a stark contrast to the way it should be, given the way a compressor works. it's letting fresh air in with the recirc. have no idea where to look, but am absolutely certain it's vacuum related. nothing else would be affected by the engine speed that I'm aware of.
gmcjimmy_94
Dec 30, 2010 12:37 AM
KC-BodyMan
Dec 12, 2009 09:22 PM
drperry
Feb 1, 2007 08:11 PM
moggy59
Jul 26, 2006 08:50 PM
dashyman
Nov 28, 2005 01:49 PM
