A/C compressor and defrost
Old Feb 1, 2007 | 07:44 AM
drperry's Avatar
Default A/C compressor and defrost
Is there any way to not have the A/C pump cycle when using defrost? Once the vehicle is warmed up, it hasn't fogged up on me... and the A/C pump makes the truck quite a bit thirstier on the fuel, lol.
Tips, hints, suggestions, gremlin commands are all welcome...
Please and thanks!
Old Feb 1, 2007 | 11:01 AM
Default RE: A/C compressor and defrost
If your compressor has that big of an impact on your fuel mileage, you've got issues larger than the compressor cycling. Even in the summer, I showed very little difference in the fuel mileage with the A/C on or off. I would really doubt that the compressor cycling as little as it does in the winter would have anything to do with your mileage.
But if you want to keep it from cycling, put a switch in the clutch circuit or just unplug the clutch.
Old Feb 1, 2007 | 05:58 PM
drperry's Avatar
Maybe I'm just used to my old Z34... Not used to all these fancy new gadgets that DON'T make things wonky, lol
But thank ya! I'll watch the mileage, and see what happens...
Old Feb 1, 2007 | 06:55 PM
pilgrim's Avatar
pilgrim is an unknown quantity at this point
Ditto to what Swartlkk said. Unless there's something wrong with the AC, the difference in fuel consumption is negligible. You could put a switch in the clutch circuit and mount the switch on the dash, but I'd suggest living with it until spring and then fixing any problems.
I suspect you have the impression that it makes a difference, but haven't actually tested it. Gas mileage always stinks when temps are cold - and that's when you use the defrosters.
If you wanted to actually find out the difference, you'd need a two-week stretch of weather that was unchanged. Fill up at the start of week #1, use the defrosters and note the gas mileage. Week #2, fill up again, disconnect the electrical connector for the compressor clutch, drive the same places, use the defrosters the same amount, and note the gas mileage. Compare, and all things being equal in terms of your driving and the number of minutes you used the defrosters, you will be able to perceive the impact of the AC unit on your gas mileage.
I'm betting that the error of your measurement will be much greater than the impact of the AC compressor engaging occasionally.
Old Feb 1, 2007 | 07:27 PM
drperry's Avatar
Probably true, lol, I just know with my old Z34, in the summer time the mileage dropped about 4MPG when I used the A/C for a tank of gas...
Ahhhh well, I'll worry about it when I get like 4MPG
Old Feb 1, 2007 | 08:08 PM
pilgrim's Avatar
Using AC for an entire tank is quite different than using the defrosters. When you use the defrosters, the AC cycles on and off occasionally, but doesn't run steadily. Much less load on the engine.
Old Feb 1, 2007 | 08:11 PM
drperry's Avatar
Good to know... My old Z's A/C must've been on the way out then, the defrost would run the pump continuously...
kendog
Nov 1, 2012 04:45 AM
gmcjimmy_94
Dec 30, 2010 12:37 AM
65longroof
14
May 2, 2009 04:58 PM
Dadet55
Nov 21, 2008 08:15 AM
kammino
Nov 27, 2006 11:35 PM
