A/C Disable?
Old Feb 9, 2010 | 05:24 PM
billybob's Avatar
billybob is on a distinguished road
Default A/C Disable?
I have a 95 Blazer LS 2wd and the a/c compressor is making a loud ratcheting noise when the pulley is engaged.the sound seems to come from the compressor and not the pulley.i don't have money to replace the compressor and don't want it to explode while driving.can i just unplug the wires on the front that engage the pulley without causing problems.don't really need a/c in Western Washington state
Old Feb 9, 2010 | 07:34 PM
Nvidia78's Avatar
Nvidia78 is on a distinguished road
Yes you can unplug the wires from the compressor, that way you will be sure that the compressor clutch does not engage, even on defrost the compressor will cycle to remove moisture from inside the cab
Old Feb 9, 2010 | 07:45 PM
wlorton's Avatar
For my 98, since the condenser got busted... we unplugged the fuse and the clutch no longer engages.... Will be like that until I get around to refilling the ac... lol
Old Feb 10, 2010 | 11:24 AM
midnightbluS10's Avatar
midnightbluS10 can only hope to improve
How exactly does your compressor bolt in? Do the bolts go in from the front of the compressor? If so, there's an A/C compressor bypass pulley that you can install to get you by. I'm 99% sure SyTy's use the same compressor and bracket.
Old Feb 11, 2010 | 03:31 AM
billybob's Avatar
Thanks everyone.I disconnected the wires and the truck seems to run a little stronger.The compressor must of been bad since I got the truck and was sucking hp, it always made a ratcheting noise but not as bad as recently.Aside from a little moisture in the cab I think this counts as a performance mod Thanks again.
Old Dec 21, 2021 | 11:53 AM
kenlani's Avatar
kenlani is on a distinguished road
Just a note about pulling the fuse ,,,if you pull the fuse #4 it will also disable the 4WD actuator---just disconnect the wires at the compressor--(I pulled the fuse and had no 4WD in a monster storm) (Thanks to George for this info)
Spectreblazer
Mar 9, 2010 12:39 AM
AutomagicLS1
15
Dec 22, 2007 08:15 PM
BLK85
Jul 6, 2007 07:53 PM
blazerium
Dec 26, 2006 01:39 PM
mleasure
Jun 7, 2006 09:58 PM
