A/C fan blowing but nothing coming out
Old Sep 26, 2010 | 07:32 PM
josephdstone's Avatar
josephdstone is on a distinguished road
Default A/C fan blowing but nothing coming out
I'm having an odd issue, after I drive the blazer for about 45 mins at about 65 or so when on max a/c the air stops being directed anywhere it just just blows against the direction changing door like it just closes. I can put it on the setting where it turns the compressor off and blows at your face and it will open the door back up and turn it back to max a/c but it does it again after a little while.
Has anyone had this issue?
-1998 Chevy Blazer LS 4.3 2WD Auto 4DR
Old Sep 26, 2010 | 07:41 PM
Thor_449's Avatar
Thor_449 is an unknown quantity at this point
you've got a vaccuum leak somewere or possibly a vaccuum clog. Most likely though it's actually blowing up through the defrost vents. Having your truck on Max a/c puts a big load on the engine so see how much vaccuum you have in your engine. should be around 17 in Hg
Old Sep 26, 2010 | 07:44 PM
iloveblazers's Avatar
iloveblazers is on a distinguished road
I had a problem with the air only blowing on my face, my dad replaced a vacuum hose and now i no longer have that problem
Old Sep 26, 2010 | 07:46 PM
Is there a most common place to get a vacuum leak? Or is it all a wild goose chase?
Old Sep 28, 2010 | 09:14 AM
Surgin's Avatar
Surgin is on a distinguished road
After 45 minutes it stops blowing, then you put it to vent and does it slowly start blowing or immediately?
I would think that your a/c lines are freezing up. Once you turn the vent on, it thaws them off and you have movement of air again.
Justin
Old Sep 28, 2010 | 10:25 AM
it doesn't take very long, maybe about 15 seconds for it to start blowing out of the vent.
MyBlazerSucks
Sep 4, 2011 12:31 AM
YOURCONNEXX
Oct 21, 2009 07:10 PM
2klt
Nov 19, 2008 07:49 PM
a_tack
Jul 24, 2007 11:04 PM
99blazerLS
Jan 3, 2007 10:35 AM
