A/C and heat issue
A/C and heat issue
I have a 2000 S-10 Blazer. 4.3L Automatic. It has the climate control heat and A/C. With the A/C on it blows cold for about 4 seconds, then heat for about 4 seconds. With the heat on it does the same. With all off you can still feel the heat coming out about every 4 seconds. I was told to disconnect the battery for fifteen minutes or so, but this didn't help. I was also told to listen for the air control doors to open and close. Hear nothing. The compresser clutch is engaged and the compresser seems to be working fine. When it does blow cold, it is very cold. I checked the freon with a guage, and it is fine.
Help Please................
Sounds like a faulty blend door actuator. It is located up on top of the HVAC housing accessible by dropping the glove box down. Small hands makes it easier to remove as does having a ratcheting low profile screw driver.
CLICK HERE for the HOW-TO
Does this vehicle have the electronic auto air? If so then it could be a defective gem module issue.
Just wondering if you found out what caused the actuator to open and close. Mine is doing the same thing.
MTopper
20
12-15-2011 12:28 AM
CSCustomCars
11-22-2010 08:24 PM
Lodi Dodi
11-12-2010 06:26 PM
