A/C - heating system dead
Old Oct 4, 2008 | 01:00 PM
Hot Rod's Avatar
Hot Rod is an unknown quantity at this point
Default A/C - heating system dead
Hi.
My entire A/C and heating system went dead today. Worked fine yesterday. I have the CCC, Computer Climate Control.
The A/C does not start, fan is dead. I´ve checked every fuse (2 locations) and the A/C relay. "Shaked" more or less every electrical connector it the fan area in engine compartment. Had the control panel outand tapped it and the connections gently.
I suspect the control panel itself, is that a "known" source of problems? Rear defogger is also dead, located on that panel.
Any other good ideas?
Old Oct 4, 2008 | 02:34 PM
Peru Motors's Avatar
Peru Motors is an unknown quantity at this point
Default RE: A/C - heating system dead
year of the vehicle might help. jp[sm=bling.gif]
*Combining Consecutive Posts*
is it the 99 mentioned in the bottom of your question box? jp
Old Oct 4, 2008 | 02:37 PM
is it the 99 mentioned in the bottom of your question box? jp[]
Old Oct 4, 2008 | 02:39 PM
Hot Rod's Avatar
If you look at the bottom of my post you will find it...
Old Oct 5, 2008 | 09:01 AM
I have not experienced this with a blazer, but on a different GM vehicle, when everything went dead, it was the head unit for the HVAC.
Old Oct 12, 2008 | 01:47 PM
Hot Rod's Avatar
Thanks for your reply, swartlkk. I think you were right. My system started working for a short while and then went dead again...
Replaced my 1999 panel#16247325 with a 1998#09351305(looked the same...) and now its working!
Old Oct 12, 2008 | 07:05 PM
mysons95's Avatar
mysons95 is an unknown quantity at this point
I'm assuming you checked your fuses.[&:]
94s10blazin
Aug 10, 2013 01:00 PM
Wayner1011
Feb 16, 2011 10:03 AM
liltittle62
Dec 26, 2010 03:55 PM
Amish3006
Jul 29, 2009 07:30 PM
rriddle3
Aug 26, 2007 04:38 PM
