A/C Pressure
Old Jul 16, 2010 | 04:40 PM
Dano01's Avatar
Dano01 is on a distinguished road
Default A/C Pressure
I was having problem with the A/C compressor kicking on for 30 sec then of for about 10-15 sec. I got a can a freon with the guage already attached and when i hooked it up it is reading around 42 PSI. I was wondering if that is good or if I need to had more. I had the blazer run for about 15-20 minutes and the compressor never kicked off.
Do I need to add more freon?
Thanks
Old Jul 16, 2010 | 05:10 PM
hubert hefner's Avatar
hubert hefner is on a distinguished road
i dont think i would add more. The pressure is already a tad on the high side. the compressor on mine kicks on and off also, i think its supposed to do that. Not 100% on that though. does it get cold? Did you bleed some air out of it when you added the r134a?
Old Jul 16, 2010 | 05:18 PM
Dano01's Avatar
It blows cold and when i went to contect it up some air came out of it.
Old Jul 17, 2010 | 05:51 PM
Dano01's Avatar
I was wondering if I need to lower the pressure.
Old Jul 17, 2010 | 06:11 PM
rknight's Avatar
rknight is on a distinguished road
What is the evaporator temp on Max A/C. Put a thermometer by the closest vent to the evaporator (right side passenger usually) and see what it is. A thermometer with a probe you can put inside would be best. I use a digital meat therm from walmart. Generally speaking, your evap temp and low side pressure should be pretty close. I have a chart somewhere around that tells you exactly.
EDIT: Like with all things psi or vacuum related, altitude matters too.
Old Jul 17, 2010 | 07:04 PM
blazerboy001's Avatar
blazerboy001 is on a distinguished road
You may need to purge the system of air.
Old Jul 17, 2010 | 09:39 PM
Dano01's Avatar
How do i need to do that.
Old Jul 18, 2010 | 09:10 PM
with the vehicle running and the ac on, take the cap off of the high pressure side and push the valve open with a phillips screwdriver and it will let the air out, just do it until r134 starts to come out. You may need to add more r134 after you bleed the air out. you should notice that the ac will be colder after you do this and your compressor shouldnt shut off as much. hope this helps.
Old Jul 19, 2010 | 06:54 AM
Dano01's Avatar
What should the PSI be after I releive some air and if I need to had some more freon.
Thanks for the info.
Old Jul 19, 2010 | 01:38 PM
Dano01's Avatar
I was wondering if anybody has every used one of these.
Smart-Charge Air Conditioning Recharge Kit
racinghoss
Sep 10, 2023 08:56 PM
olilsteveo
Jan 26, 2010 03:19 PM
93BlazerGyrl
Dec 13, 2009 12:37 PM
Spartan66
Jul 11, 2008 02:34 PM
jlinder
Aug 21, 2005 11:08 AM
