fuel pressure problem?? HELP!
Old Apr 16, 2005 | 07:30 PM
racinghoss's Avatar
racinghoss is an unknown quantity at this point
Default fuel pressure problem?? HELP!
I have a 97 4 door blazer, AWD, that is having problems starting. Here is the deal:
When trying to start it, it turns over but it seems like there is a fuel delivery problem. It just keeps turning over without firing. Here is the weird part, if I "jump start" it by hooking it to my Jeep, it will start. However, it is not the battery in the blazer that is the problem, it is a brand Optima Red top. The charging system is fine, alternator and everything checks out OK. It seems like it just needs a little kick in the pants to get it going. Fuel filter is fairly new, its a recurring problem so I have discounted bad gas. I have run 2 bottles of SeaFoam through it and had it in the shop for the "professional" fuel system cleaning. Once it is running it runs fine, the problem is only with starting it. Also, once it has been started and run for a while, it will USUALLY restart again just fine. It just seems like it is not getting enough fuel pressure at startup.
Since I cant start it and the battery has been disconnected, I cannot get any codes from it.
Any ideas?
Old Apr 17, 2005 | 12:21 AM
Im_Bryan's Avatar
Im_Bryan is an unknown quantity at this point
Default RE: fuel pressure problem?? HELP!
Hi there...
My moms 96 4dr blazer 4x4 is having (sounds like) the same problem... Instead of jump starting it she pours a small amont of gas down the throttle body and it starts right up... It has the same symtoms as yours... She has put in a new fuel pump and temp sensor in it... We have checked the battery and altinator as well and everything checks out ok...
Will try jump starting it instead of the gas to see if its exactly like yours...
The only "code" we had was for basically a bad gas cap.... Which was replaced..
I havent heard to much information back on the problem yet but I will keep you posted if I do...
Bryan
Old Jun 16, 2005 | 03:17 PM
mel's Avatar
mel
mel is an unknown quantity at this point
HI I AM HAVING THE SAME PROBLEM ON MY 95 BLAZER CURRENTLY . HAVE YOU FOUND ANY FIXES .. IT IA A PAIN ....
AFTER GETTING IT STARTED THE SAME AS YOUR ..IT OK . BUT AFTER IT SITS OVER NIGHT ITS THE SAME AGAIN..
PLEASE ADVISE ON THE FIX
6.16.05
MEL
melalice2002@yahoo.com
Old Jun 21, 2005 | 07:14 PM
Chevyboy07's Avatar
Chevyboy07 is an unknown quantity at this point
I had the same problem with my 96 2 door blazer. At first I thought it was the fuel filter so I changed it and found it was bad but it still did it. I took it to my mechanic and he thought it was a loose wire because it was gettin fuel but once he ran the computer it turned out I needed a fuel pump and it cost about $400.
Old Sep 10, 2023 | 08:56 PM
Vicjordan's Avatar
Vicjordan is on a distinguished road
Any ideas?
Inject propane into the air filter on the first start of the day. If it starts immediately then fuel pump needs replacing.
silver bullet80
30
Jun 6, 2011 01:21 PM
Bad Ramer Jamer
Sep 16, 2008 10:32 AM
Spartan66
Jul 11, 2008 02:34 PM
gpr13902
Apr 29, 2008 10:12 PM
adlady
Aug 26, 2007 01:35 AM
