A/C Where to start,98 Blazer
The air worked fine last year but not at all now, The compressor kicks in and out in 1-2 second intervals.
Only thing I did to the engine was replace intake gaskets over the winter but was carefull not to pop any system
hoses or seals.
Where should I start looking??
hoses or seals.
I just recharged my 96 with a redtek kit. the gauge was doing the same thing until i put 2 cans of 12a in it. when the the compressor stayed on after enough fluid was added the gauge did not flick around. i charged it to around 38psi. now its blowing cold air. becareful not to over fill.
Jumper the A/C relay to keep the compressor on all the time and fill until the gauge gets to the appropriate zone. You can also just keep charging until the compressor stays on.
The pressure in the lines evens out when the compressor shuts off so you really aren't overcharging it. What you are experiencing is that the pressure is higher than the recommended pressure while the compressor is engaged. It really isn't indicative of what the pressure is when running as you have already experienced.
If the low side pressure drops to nothing though, it could indicate that your orifice tube is plugged...
If you jumper the relay underhood, does the system cool properly or atleast make an attempt to cool?
djmehkae
Nov 7, 2017 08:08 PM
FreeTime
Sep 8, 2012 01:38 AM
Larhatch60y
Nov 8, 2007 01:05 AM
actionpaintball
Jul 14, 2006 07:53 PM
apekim
Jun 30, 2006 10:38 AM
