A/C wierded out!
Old Sep 1, 2012 | 08:37 AM
hewybo's Avatar
hewybo is on a distinguished road
Default A/C wierded out!
2nd new compressor!!; new accumulator; new orifice tube; new condensor; new o-rings; new high-side tube (factory GM); 2nd set new gauge manifold. Flushed system - vacuumed to 28 for 1 1/2 hrs; pump off, held vacuum 1 hr. no fluctuation. new pag 150 and r-134a charge. no leaks under uv light. compressor cycles on and off (set to max) -and acts like there's not enough freon to compress! i am at my OLD MAN'S WIT'S end!! any HELP???!!!???
Old Sep 1, 2012 | 07:13 PM
Blue00Blaze's Avatar
Blue00Blaze is on a distinguished road
I have a similar issue of the compressor constantly turning cycling within 20 second or shorter intervals it is very annoying when trying to accelerate. But the air comes out of the vents ice cold.
You did not mention if you were getting cold or warm air coming out of the vents is the problem no cold air? or the compressor cycling to much?
Old Sep 2, 2012 | 09:06 AM
hewybo's Avatar
apparently i don't know how to use gauges.. had the pressures dead on shop manual specs...it was overfull, and the high pressure switch was kicking out the compressor...evacuated some freon..now it's fine, but the high side pressure is less than 100 (manual calls for 300+, low side @ 20- manual says 35)...don't know what to think, but it's blowin cold...???
BlackBastard
Jul 7, 2011 11:31 PM
redblzr4x4
Feb 23, 2010 09:53 PM
ChevyBlazerChick
Aug 26, 2009 08:12 PM
stevenf
Lifting Tech
May 9, 2008 11:38 PM
95_4door
Nov 11, 2007 12:02 AM
