Cad cable
Old Feb 8, 2009 | 04:34 PM
brkenblazer's Avatar
brkenblazer is an unknown quantity at this point
Default Cad cable
Good afternoon all , I recently purchased a 95 blazer for 500 only thing it need was a heater core and a windshield. Took care of that , now having issues with the 4x4 , i have been reading post for a few days and it all ends up with the vacuum , i have taken that out the picture and run a homemade posi-lock. I put the front wheels off the ground put the tranny in neutral and push 4 hi front driveshaft locks into place and i hear a click, i pull the posi-lock and nothing happens, i unhook the posilock and climbed under the truck with it running and 4 hi locked in and tryin to manually pull the cable and nothing is happening , i pull it and hear a click and thats it. Could i have a issue with the fork inside the diff, or the gears mounted on the shaft . i keep beating my head against the wall and cant figure it out , i wanted to put this message out there before i tear into the front diff myself . Thank you all , hope i can fix this . I hate being stuck in jersey mud with no 4 wheel drive
Old Feb 8, 2009 | 04:35 PM
Default RE: Cad cable
Sure sounds like the problem resides in the front passenger axle tube. I would start by removing the cable entry bracket and seeing how everything looks inside there. You should be able to see the shift fork and collar.
Old Feb 8, 2009 | 04:58 PM
Thank you for a fast reply. Could you tell me what i should be looking for . I need to pull the passenger cv axle and tube to get to what i want . I know its a hard question, but do you think its as easy as pulling off the axle tube and looking and i might lucky. Is there a diaghram of what it should look like thanks again
Old Feb 8, 2009 | 08:57 PM
Someone posted a link to ZR2usa.com (closed site) which showed the innards of the passenger side front axle. You can remove the three bolts which hold the cable bracket/housing on and have a look. This does not require the removal of the axle tube.
Old Feb 9, 2009 | 06:34 AM
SockJock's Avatar
SockJock is an unknown quantity at this point
first lift the front and try putting it into 4Lo and see if it engages then. It still could be a transfer case switch issue.
TexasRider
May 30, 2013 09:10 AM
Squad-6
Apr 22, 2013 02:19 PM
nickdouglas
Sep 30, 2009 02:09 PM
Hanr3
Jan 22, 2007 02:30 AM
haubritches
Mar 22, 2006 03:39 PM
