Call me a hack but...
Old Sep 23, 2009 | 03:57 AM
  #31
awe341's Avatar
awe341 is on a distinguished road
I don't get why you think that dropping the tank is such a big deal in the first place. It seems to me that you are doing tons more work to cut a hole in your truck instead.
There are two straps that hold the tank up that are secured by all of one or two bolts each depending on your model year. It will take a maximum of 15 minutes to remove the tank the right way. (That includes removing all wiring and hoses and assuming all bolts are rusty)
As for having to do it again and again. If you actually bother to buy a name brand pump, replace the wiring harness as recommended, and replace the fuel pump relay also as recommended. Then you should not have to replace the pump again for the rest of your trucks life.
Old Sep 23, 2009 | 05:58 AM
  #32
W2JGA's Avatar
W2JGA is an unknown quantity at this point
Oh I'm really curious now. So if you cut the hole to just a tad bit bigger than the sending unit/pump diameter, just how in the world are you going to remove that ring that holds the assembly in place?
Stop wasting your time and just drop the tank.
Old Sep 23, 2009 | 11:23 AM
  #33
republic's Avatar
republic is on a distinguished road
Well that's the beauty of cutting the hole to small. Then you could cut it bigger!!
I like the idea. I've changed three pumps in the the last three years. A Suburban, an S-10 and a Caprice. Even with good parts I've been concerned that something would fail and I would have to drop a tank right after an install.
Looking foward to more updates.
Old Sep 23, 2009 | 12:10 PM
  #34
abig84's Avatar
You guys must have never dropped a tank on a rusty ol mud trucks... The straps will break and need to be replaced. The lines will probably be rotted to the rubber hoses so the hoses have to be replaced. And lowering or draining a 41 gallon tank half full of fuel with a floor jack sucks. Access panel takes 1 minute to do.
Also helps if u have ground wire or other issues later on down the road. If you have a nice truck I wouldn't recomend it
Old Sep 23, 2009 | 04:34 PM
  #35
amazinnblazin's Avatar
amazinnblazin is an unknown quantity at this point
For the record, I am now convinced the 'hole' idea is much better than taking the thing off, unless you need major repairs (the old mud truck)
Old Sep 23, 2009 | 07:56 PM
  #36
blazeitupdrgonzo's Avatar
blazeitupdrgonzo is on a distinguished road
this is getting interesting. . . haha
Old Sep 23, 2009 | 08:30 PM
  #37
bandidolenny's Avatar
I'm still waiting to to the pics! I wanna see just how clean looking this comes out...
Old Sep 23, 2009 | 08:56 PM
  #38
JSBlenz9498's Avatar
JSBlenz9498 is on a distinguished road
Ha! 15 minutes to drop the tank... your out of your mind... If you have ever worked on a car before nothing ever goes perfectly, especially an 11 year old truck from the northeast. And trust me, i have done the research on your so called, "name brand pumps," ya they blow.
I'll be buying a new cutting wheel for my electric die grinder tomorrow so i may have some updates soon.
Old Sep 24, 2009 | 12:45 AM
  #39
old skool luvr's Avatar
sorry guys, but there was waaaaay too much here, to just let some go by......
Originally Posted by okvortec
You're going to cut the gas tank, I'm calling it.
i'd be surprised if something didn't get cut, sawzall/die grinder, i don't care, somethings going down!
Originally Posted by bandidolenny
Oh Puleeze!... You have got to post some pics of this!
screw the pic's! i wanna see video of this. where the popcorn?
[quote=abig84;247114].......some foregn cars actually come with a access panel in the trunkquote]
that's because the pumps break down so often! (i've owned three VDubs, this is thier biggest problem IMO)
Originally Posted by abig84
though i did have a friend drill into his tank on a 82 camaro trying to install a amp
oops!
absolutely right big. and yeah, i've had to drop a full tank in my Burb, thought it was the pump. after draining it, swapping the pump, it turned out to be a short in the wire, and popped the fuse. can you say double
[quote=JSBlenz9498;248148]Ha! 15 minutes to drop the tank... your out of your mind... If you have ever worked on a car before nothing ever goes perfectly, especially an 11 year old truck from the northeast.quote]
i'll give ya that JS, any place where you see any kind of winter, you can be guaranteed of rust trying to stop you.
now, after all the bashing we've given you on this subject, are you gonna share your results with us when done?
Old Sep 24, 2009 | 09:39 AM
  #40
republic's Avatar
Nothing has to be damaged. If there were only a half inch of clearance there is still space to slide a shield between the tank and floor to protect the wires and hoses from being cut. This is a quality idea and a great mod for those of us planning on keeping their trucks for a while.
