Camber bolt replacement question
Old Mar 23, 2021 | 10:07 AM
Ladyblake's Avatar
Ladyblake is on a distinguished road
Default Camber bolt replacement question
Ok people I jus bought a 99 Blazer 4x4 sport utility. There was some play in the while driving it would randomly pull 1 way or the other. I take it for an alignment & they say there is 2degree on the camber that the camber bolts need to be replaced. Me... I'm nt so sure, ur thoughts?
Old Mar 23, 2021 | 03:04 PM
Wouldn't doubt it, bolts themselves are cheap, and if they know what they are doing, doesn't take long. Should ask how much they are looking at for hrs.
If they didn't tell you that you needed ball joints and tie rods and sway bar links, I would say the camber bolts would be a good call...
Old Mar 24, 2021 | 05:06 PM
LannyL81's Avatar
I think when they told you camber bolts, they really meant the camber cams and bolts....they come as a set. Each front wheel takes a pair of bolts/cams...so four total. Pretty easy to replace unless the old ones are all corroded.
You can check prices out on RockAuto and see a picture of what they are talking about.
waltbiller
Aug 16, 2020 06:19 PM
jimdian
Aug 15, 2020 08:53 AM
95blazerlt
Mar 8, 2014 05:40 PM
jimmyjam8586
Oct 27, 2012 04:24 PM
urbex
Nov 27, 2009 06:17 PM
