Can I drive it??
Old Nov 1, 2008 | 03:23 PM
mcblaze's Avatar
mcblaze is an unknown quantity at this point
Default Can I drive it??
Just got back from a trip with my 98, and i'm leaking antifreeze. I bought the truck a few months ago and noticed the overflow tank was low, so i filled it. It's been ok until i noticed this leak. It looked like it was coming from the water pump, but after reading some related threads I believe its the intake manifold. It's turned into quite the leak too!
Rather than pay to have someone do it, I'd like to tackle it myself. Problem is my do-it-yourself shop is 2 hours from where i live. What are the risks if I drive the truck?
Thanks-
Matt
Old Nov 1, 2008 | 03:52 PM
rriddle3's Avatar
Default RE: Can I drive it??
ORIGINAL: mcblaze
...What are the risks if I drive the truck?
Thanks-
Matt
Overheating and engine damage. You need to be certain of the source of the leak. If you don't have the eqipment to do so, have a shop pressure test the coolant system to locate the leak.
Old Nov 2, 2008 | 03:10 PM
The potential risks Rich mentioned and that is what will happen if your coolant level drops too low. If your cooling system is full, and you check the level often (get a Stant safety cap before you try driving that far so you can check the radiator level with a hot radiator), then you should be able to make it where ever you need to go. Just make sure that is where the leak is located so you can be sure to have the appropriate tools and materials (gaskets, etc) on hand to affect repairs.
Old Nov 2, 2008 | 05:51 PM
mcblaze's Avatar
Update:
I let it idle up to normal operating temperature, ran the heater, etc. hoping to find the leak. After I shut it off, and let it cool down, no leaks.
I topped off the overflow tank & radiator and took it for a ride in an effort to get it warm and regenerate the leak. Again, let it cool down and noticed wetness underneath the backside of the water pump. I did just replace the belt about two months ago so i'm wondering if the tighter belt might have put different pressure on the water pump pulley????
I'll have to get a Stant saftey cap for sure. So i'm guessing that If i replace the water pump and gaskets I should be good to go. What do you think?
Old Nov 2, 2008 | 06:41 PM
If you are sure that the water pump is at fault. VERY rarely will a water pump fail at the back after being in operation for a long while... Typically, the water pump will leak at the front seal.
Old Nov 2, 2008 | 07:16 PM
doodad69's Avatar
doodad69 is an unknown quantity at this point
Might want to check your oil level too. If there is a chance your intake is leaking, it might get into your crankcase. That happened to one of my V8 trucks and killed it. Even a small amount of antifreeze is very bad for your bearings.
Old Nov 5, 2008 | 04:44 PM
mcblaze's Avatar
Update:
Just had the cooling system pressure tested for $20. Mechanic says I need a new water pump. They quoted me $350 (outrageous) so Ive found myself a weekend project. I appreciate the replies.
Thanks-
mirrorimij
Jun 8, 2019 03:34 PM
Blade_24k
Feb 26, 2014 03:03 PM
lizzj70
Jun 23, 2010 06:57 PM
carterx
May 21, 2009 08:30 PM
watsonracingteam
Aug 27, 2008 10:14 PM
