Can I Wire Driving Lights Using Factory Switch?
Old May 14, 2010 | 09:34 PM
Lone Star's Avatar
Lone Star is an unknown quantity at this point
Default Can I Wire Driving Lights Using Factory Switch?
I have a '97 Blazer 4wd. I would like to wire a set of driving lights using a factory switch. Right now the spot for the switch has a blank, however when I had the dash bezel off, I noticed what looked like the factory wiring for the switch. There is also wiring and plugs at the front bumper where the lights would be. My question is, can I just get the factory switch and plug it into the wiring in place and go? Or am I hoping for too much?
Old May 14, 2010 | 11:51 PM
bumpinblazer94's Avatar
bumpinblazer94 is on a distinguished road
dont know a whole lot about the factory wiring, but if it comes down to it you can wire them up with a relay, using a hot from the factory headlight switch as the switch for the relay, its really not that complicated if you have a test light or acces to the factory wiring diagrams
Old May 15, 2010 | 06:45 AM
The problem is that most factory switches are momentary switches, meaning they do not latch on or off. To use one, you would need to setup a latching relay arrangement that would take that momentary pulse (when you press the button) and turn on and off the relay(s). the12volt.com has schematics for latching relay arrangements.
I would try to find a way to just put a toggle or latching push button in the factory location.
Old May 15, 2010 | 12:32 PM
i wasnt refering to the factory fog light switch , but the actual main headlight switch. that is either on or off, it does not return back to original position when u turn them on, so it would work fine with a standard 4 or 5 post relay
phxjosh
Jun 13, 2013 04:21 PM
brad_blazer
Oct 28, 2010 11:13 PM
urbex
Nov 23, 2009 05:50 PM
Vortec4300
Nov 22, 2008 01:06 PM
bubba181x1
Mar 12, 2008 02:05 AM
