How do you wire up driving lights?
Old Nov 15, 2008 | 10:49 AM
Vortec4300's Avatar
Vortec4300 is an unknown quantity at this point
Default How do you wire up driving lights?
I have an 04 Blazer with DRL. I'm trying with little success to wire up a set of Hella 500 driving lights to come on with the high beams, go out with the low beams and stay off with the daytime running lights. Has anyone done this and kept everything else working correctly in the process?
Old Nov 15, 2008 | 12:21 PM
riceh8r0512's Avatar
riceh8r0512 is an unknown quantity at this point
Default RE: How do you wire up driving lights?
Well...I have not actually done this, but I am in the plans of doing so. If I remember right, the Daytime Running Lights are the high beams, only not at full power. So what I have been looking into is getting a relay that will require a certain voltage before turning on, so a relay that will require more voltage than what the Daytime Running Lights will give, but when the high beams come on, there will be enough voltage to flip the relay. Like I said, I have not actually done this yet, but from my understanding, that will work.
Old Nov 15, 2008 | 12:27 PM
Vortec4300's Avatar
Thanks, sounds like it should work.
Old Nov 16, 2008 | 06:07 PM
Let me know how it works out, I'd like to know if I have to change my strategy with it.
Old Nov 16, 2008 | 08:39 PM
Vortec4300's Avatar
I actually asked about the special relay on another forum thats geared towards custom auto electronics, stereo installers, etc. I'll let you know what I find out. Surely we're not the only ones to put driving lights on a late model GM with DRL. I know someones figured out how to do it.
Old Nov 19, 2008 | 05:14 AM
rx7_guy's Avatar
rx7_guy is an unknown quantity at this point
You simply need to have a relay wired that will close the circuit for the Hella's when the high beams are cut on...just remember to use a good relay...always run a fuse or Circuit breaker and decent gauge wiring.
Old Nov 22, 2008 | 01:06 PM
Vortec4300's Avatar
Figured it out. You have to ground the driving light relay to the high beam ground wire not the chassis ground. In my case with an 04 model, run the signal wire for the relay to the green wire in the left side highbeam harness and the relay ground wire to the purple wire in the samehighbeam harness. Driving lights come on with the high beams, go off with the low and DRL work normally.
slcblazer
Jul 13, 2013 02:28 PM
DJ 4x4
Sep 26, 2011 09:44 PM
Lone Star
May 15, 2010 12:32 PM
BDS_237
Apr 19, 2010 11:05 PM
bubba181x1
Mar 12, 2008 02:05 AM
