can"t remove fan
Old Nov 21, 2009 | 06:14 PM
bad havette's Avatar
bad havette is an unknown quantity at this point
Angry can"t remove fan
Trying to get to my water pump.(99 Blazer)Anyone remember if the fan nut is reverse thread?
Old Nov 21, 2009 | 06:15 PM
oisinirish's Avatar
Which way does the fan spin when the engine is running? thread sougl be opposite to avoid the obvious.
Old Nov 21, 2009 | 06:25 PM
tazz9690's Avatar
tazz9690 is on a distinguished road
it's not reverse thread on my 02 blazer. I just zipped it off with a pneumatic gun and a spanner wrench made for pneumatic air guns
Old Nov 21, 2009 | 06:26 PM
How about in plain english?
Old Nov 21, 2009 | 06:32 PM
oisinirish's Avatar
Spin the nut in the same direction as the fan turns.
Righty Tighty, Lefty Loosie.
Old Nov 21, 2009 | 06:44 PM
I tried jamming 13mm box end between pulley bolt and a mount then a large spanner on the nut to left (with heat) and it's not budging.I don't have a jtool?.
Old Nov 21, 2009 | 07:09 PM
I have used a large crecsent wrench and a pry bar quite a few times. Find a pulley bolt where the pry bar can be inserted and not rest directly on a flat (more on a point) of the hex of the fan clutch. Then just turn the large hex with the crescent.
Another method I have used is to have someone hold additional tension on the belt. Then take the large crescent and hit it with a hammer for added shock. This is actually the method I use first.
Old Nov 22, 2009 | 09:19 AM
terry s's Avatar
terry s is on a distinguished road
See if your auto store has a loaner tool for removing the fan.
OReilly has a pamplet listing all of their loaner tools. I keep it next to my tool box. It lists about 50 different tools.
They show a fan clutch wrench set # 67063 which should do the trick.
Old Nov 22, 2009 | 07:56 PM
Thanks for all the input. I went to my local hardware store , found a piece chain the right size for the bolts (water pump pulley) attached it to the nearest empty bolt hole and was able to crack the fan nut.Everything else was downhill from there.
pmzusmc
Apr 19, 2011 05:44 PM
ComputerNerdBD
Feb 28, 2010 11:30 AM
volfan4
Nov 28, 2009 08:04 PM
midnightmekanik
Oct 8, 2009 08:32 PM
cide
Mar 23, 2009 10:57 AM
