Cant get front differential mounting bolts loose...
Old Feb 16, 2019 | 05:00 PM
BeaterJimmy's Avatar
BeaterJimmy is on a distinguished road
Default Cant get front differential mounting bolts loose...
Hey all,
Can I please get some advice from someone who has pulled the front differential on a 99 Jimmy SLE? What tool set up did you use to get the mounting bolts loose?
I have my entire front end apart to replace some output bearings and seals but also have a bad motor mount I was going to take care of except the mounting bolts (and nuts, the bastards) are super difficult to get to with anything other than an 18mm open end...
any help is appreciated.
Old Feb 16, 2019 | 07:48 PM
cleburne red's Avatar
Not sure how different your truck is from my 95 Blazer, but I was able to get all the bolts loose with an impact and backup wrenches.
The lower diff mount will probably have to be cut and rewelded, from what I've read. I was installing a lift kit, that used a different mounting location, so I wasn't worried about it.
jjm90sc
Dec 4, 2018 11:28 AM
99Legendary
Mar 28, 2012 01:51 PM
kaybell110
Mar 30, 2011 03:56 PM
myol blue4x4
Jul 23, 2008 12:26 PM
95Blazer4x4
Mar 7, 2008 07:54 PM
