Can't get it started - 98
Hey guys..
parked my blazer about 4 months ago and haven't messed with it since. Went out today, it won't start... I added 2 gallons of gas to the tank and tried dumping some in the top of the throttle body.. if I do, it will start and run for maybe 2 or 3 seconds, then die.
I can hear the fuel pump whining when I have the key in the on position so I think it's still operational.. any ideas?
I will try and get the tools necessary for that asap.
I wanted to run something by you guys:
On top of the tank with the pump, there are a bunch of cut wires. One wire runs from a 10 AMP fuse in the engine bay to the pump, one runs from the pump to the GROUND post on the battery. Any idea why this would have been done? It was clearly done by a previous owner.. I noticed a while back if I disconnected the cable from the battery *or* the fuse, it would not start (just like it doesn't now.)
USMC3782
07-12-2012 08:20 PM
kgkern01
15
07-23-2011 11:17 AM
theboyewonder
12-08-2010 08:49 PM
