cant index the encoder motor on to the tcase ..
Old Apr 19, 2012 | 08:46 PM
xgiovannix12's Avatar
Default cant index the encoder motor on to the tcase ..
hey guys i pulled the encoder motor from the transfer case today since i pulled code 2
I had a spare encoder motor on the side but i cant get it to line up with the tcase shaft.
I tryed lineing it up in all 3 modes 2hi 4lo 4hi IM just getting frustrated
other then that i tryed shifting the motor its self and still cant get it to line up
any advice is well appreciated . I have only found 2 threads on this and still cant succeed ... =(
Old Apr 19, 2012 | 09:07 PM
You can probably feel the detents when you manually shift the transfer case. The encoder is most likely in between shift points, that's why it won't line up. If you manually shift the case to 2WD HI, then select 2WD HI on the dash switch with the ignition ON, the TCCM should move the encoder to the 2WD HI position. Just a thought, worth a try.
Old Apr 19, 2012 | 09:27 PM
Well i got her to finally line up but shes stuck in 4hi ... the encoder motor tryed to go to 2wd
but wont shift I know the motor is between 2hi and 4lo
I have the tcase shifted to 4hi and the motors input in the center
Edit: I forgot to mention this is on our 97 s10 pickup and it has a 233 tcase in it
I pulled the motor off again hope I get it working again tomorrow ...
Old Apr 23, 2012 | 06:53 AM
vic98blazer's Avatar
vic98blazer is on a distinguished road
i remember reading somewhere that the t case has to be in neutral to get the motor lined up right
Old Apr 23, 2012 | 01:04 PM
It doesn't necessarily need to be in neutral: The 233 selectable case does not have a "neutral" position. The important thing is that case and the encoder are in the same position, ie, both in 2HI, both in 4HI, or both in 4LO.
Old Apr 23, 2012 | 01:12 PM
yup I finally got it that night
thanks guys
LesMyer
38
Jan 9, 2020 11:45 AM
Jimmy_Blazer
Feb 22, 2012 10:50 AM
91chevywt
Mar 24, 2010 09:24 PM
dusted800
Nov 18, 2006 10:27 PM
